Status | Link | Version | MD5 | Includes |
Stable | Download | Raspbian Stretch 9.0 | zip: XXXX img: XXXX | 2018-10-14 updated AlarmDecoder 1.13.4, AlarmDecoder-webapp 0.8.2, Built using a PiBakery recipe See the AlarmDecoder PiBakery wiki page. |
Stable | Download | Raspbian Jessie 8.0 | zip: 3a001426b1a3a2793bea589cfc93be39 img: c5e50da07e5d084ad76abd591ab605f2 | 2018-05-29 updated AlarmDecoder 1.13.4, AlarmDecoder-webapp 0.8.2, Supports the Raspberry Pi Model B, B+ and B2, and B3. Wifi and Bluetooth are both functional on the Pi 3 |
- Login
- pi
- Password
- raspberry
- Login
- admin
- Password
- alarmdecoder
