Revision as of 15:39, 15 October 2018 by 10.10.0.12 (Talk)
AD2PI Bundle
API
Stable Download Raspbian Stretch 9.0 PiBakery build zip: cc7e267d2f3bd377a239b3ebc996f491 img: 275635f7ca7ad70e951bea1f68593c86 2018-10-14 updated AlarmDecoder 1.13.4, AlarmDecoder-webapp 0.8.2, Built using a PiBakery recipe See the AlarmDecoder PiBakery wiki page.
Stable Download Raspbian Jessie 8.0 zip: 3a001426b1a3a2793bea589cfc93be39 img: c5e50da07e5d084ad76abd591ab605f2 2018-05-29 updated AlarmDecoder 1.13.4, AlarmDecoder-webapp 0.8.2, Supports the Raspberry Pi Model B, B+ and B2, and B3. Wifi and Bluetooth are both functional on the Pi 3
Login
pi
Password
raspberry
Login
admin
Password
alarmdecoder
AD2PI case assembly
File:Case assembly doc.pdf
