K | Send message from specific partition or keypad address. Addressed Message |
R | Host Acknowledge the CRC message was valid. |
\x01\x01\x01 | Send Special Key #1 |
\x02\x02\x02 | Send Special Key #2 |
\x03\x03\x03 | Send Special Key #3 |
\x04\x04\x04 | Send Special Key #4 |
\x05\x05\x05 | Send Special Key #5 |
\x06\x06\x06 | Send Special Key #6 |
\x07\x07\x07 | Send Special Key #7 |
\x08\x08\x08 | Send Special Key #8 |
a | DSC ONLY(deprecated use Special Keys): Arm Away |
s | DSC ONLY(deprecated use Special Keys): Arm Stay |
c | DSC ONLY(deprecated use Special Keys): Toggle Chime |
0123456789*#<> | Send key to panel |
Arming
The K command can be used to send a message to the panel from a specific keypad address or keypad partition for DSC. There are two parameters: The address or partition a zero padded 2 digit address or partition and the message to send. The AD2* will stay fixed on this new address until a new K message is received or the AD2* is reset or a \r or \n character is received.
- K011234\r
- K1912343\r
Special Keys
Code | Description | Ademco | DSC |
\x01\x01\x01 | Special Key #1 | Fire/Prog. | Fire |
\x02\x02\x02 | Special Key #2 | Police/Prog. | Police |
\x03\x03\x03 | Special Key #3 | Medical/AUX/Prog. | Medical/AUX |
\x04\x04\x04 | Special Key #4 | Programmable | Stay |
\x05\x05\x05 | Special Key #5 | N/A | Away |
\x06\x06\x06 | Special Key #6 | N/A | Chime |
\x07\x07\x07 | Special Key #7 | N/A | Reset |
\x08\x08\x08 | Special Key #8 | N/A | Exit |
0x0008 | Enable the prefixing of panel messages with !KPM. |
0x0010 | Disable DSC locking (experimental). |
0x0080 | enable CRC Delivery confirmation for LRR,EXP,REL etc. |
[00110011000000003A--],010,[f70700000010808c18020000000000],"ARMED ***STAY** ZONE BYPASSED " | |||
[00110011000000003A--] | 010 | [f70700000010808c18020000000000] | "ARMED ***STAY** ZONE BYPASSED " |
17 | System specific bits. 4 bits packed into a HEX Nibble [0-9,A-F] |
18 | Ademco or DSC Mode A or D |
If you have a Long Range Radio device attached or have emulation enabled the AlarmDecoder will report LRR messages from the panel to the radio. The format of the data encapsulates the SIA DC-05-1999.09 standard for Contact ID reporting.
- ARM STAY USER 002 partition 1
- !LRR:002,1,CID_3441,ff
- DAY/NIGHT ALARM ZONE 9 partition 1
- !LRR:009,1,CID_1135,ff
- ALARM CANCEL USER 002 partition 1
- !LRR:002,1,CID_1406,ff
- ARM STAY OPENING user 002 partition 1
- !LRR:002,1,CID_1441,ff
!LRR:012,1,CID_1441,ff | ||||
Header | Event Data | Partition | CID MESSAGE | Report CODE |
!LRR | 012 | 1 | CID_1441 | ff |
CID Message
This is CID message for the event. See below for a description and what (if any) programming fields are required for activation. It is prefixed with "CID_" and then 4 digits that are described in section 5.1.2.2 of the SIA DC-05-1999.09 standard.
CID_QXYZ | ||
Header | Event qualifier | Event code |
CID_ | 1 | 441 |
Header
Static string "CID_"
Event qualifier
1 = New Event or Opening 3 = New Restore or Closing 6 = Previously reported condition still present (Status report)
Event code
(3 Hex digits 0-9,B-F) Event codes are 3 hex digits and are broken down in classes by the first digit.
100 Alarms 200 Supervisory 300 Troubles 400 Open/Close REMOTE ACCESS 500 Bypass/Disables 600 TEST/MISC
For more detail on specific report codes see the list see Appendix C in the SIA DC-05-1999.09 standard.
Header | AUI Data | ||
!KPE:18 | |||
Header | Keypad Address | ||
!KPE | 18 |
!ERR:4,4,4 | |||
Header | Error list | ||
!ERR | 4,4,4 |
Error number | Description | ||
0 | No issues to report | ||
4 | Keypress send failure |
CRC
The CRC Message container is a wrapper around all of the standard !XXX event messages above with the checksum value at the end. The checksum is a CRC-CCITT-16 with a polynomial of 0x1021 of all of the Event Data bytes. Enable via CONFIGBITS
!CRC:!LRR:000,1,CID_1121,ff,282d | |||
Header | Event Data | CRC | |
!CRC | !LRR:000,1,CID_1121,ff | 282d |
!VER:ffffffff,V2.2a.8.2,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB;DS;ER | |||
Header | Serial number | Firmware version | Firmware capabilities |
!VER | ffffffff | V2.2a.8.2 | TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB;DS;ER |
Firmware Capabilities | |||
Flag | Description | ||
TX | Ability to transmit to the panel | ||
RX | Ability to receive from the panel | ||
SM | Supports sending multiple keypresses | ||
VZ | Virtual zone expanders | ||
RF | Supports receiving of RF messages from the 5800 series wireless devices (!RFX) | ||
ZX | Supports receiving of messages from zone expanders (!EXP) | ||
RE | Supports receiving of messages from relay (!REL) | ||
AU | AUI support (!AUI) | ||
3X | Special Keys (S1-S4) must be sent 3 times to trigger | ||
CG | Serialized configuration string | ||
DD | Message deduplication | ||
MF | Address mask filter | ||
LR | Long range radio messages (!LRR) deprecated see L2 | ||
L2 | Long range radio messages (!LRR) with CID reporting format | ||
KE | Keypad event messages (!KPM) | ||
MK | Multiple keypad emulation (See 'K' command for more information) | ||
CB | Config bits | ||
DS | DSC support | ||
ER | Error tracking | ||
CR | CRC Wrapper around EXP,LRR and other event type messages |
