  • Open Source Plugin API
    • C# examples included
  • Network connectible
Extensions can be loaded or unloaded using the about screen and install plugin menu.
  • mystuff
  • Program Downloader
  • Zone Tracker
  • HTML5 web browser tab
  • Webcam viewer tab
Operating System Version MD5
Windows 2.0.10 052e0415e55e9ea71a506cf109931a11
Linux 2.0.10 e676236858f1cb11cbe122015b38450b
Mac OSX 2.0.10 d1ae7f6a3ab49d93cedf399fbd3b98c7
Raw files no install 2.0.10 0014c98e3e1409cb49a5e10451b1a702
Update DSC support 2.0.10 d38eb8114abf8e32219902a7eff5d50d
The Windows installer will add most or all of these requirements automatically. For Linux and OSX install the required components before running the app or attempting to install.
