Make sure that you have read the Quick Start guide and watched the installation videos found in the Getting Started section.
Troubleshooting Steps
- Does the AlarmDecoder have power?
- Make sure the LED on the AlarmDecoder is flashing about once per second.
- Check your power connections if you do not see the LED flashing.
- Does the connected computer show an attached device?
- Windows: Confirm the device is present in the Device Manager.
- On some installs of windows it is necessary to enable the VCP option for the driver.
- OSX/Linux: Check your syslog and look in /dev.
- Can you communicate with the device with a terminal program?
- Open the device with your favorite terminal program. We suggest one of the following:
- Windows: PuTTY
- Select the Serial option.
- Enter the COM port number. You can look this up in Device Manager.
- Enter the speed.
- AD2USB & AD2Pi: 115200
- AD2Serial: 19200
- Click Open
- OSX/Linux: screen
- Open a terminal
- Locate your device by checking syslog or your /dev directory
- Execute screen [device] [baudrate]
- Baudrate:
- AD2Serial: 19200
- Baudrate:
- Windows: PuTTY
- Confirm that you can reboot your Alarm Decoder by typing: =
- Make sure you cleanly exit your terminal program.
- PuTTY: Click the X
- screen: Ctrl + A + K
- Are you seeing messages from your panel?
- Confirm that the AlarmDecoder is wired correctly to your panel. See the videos above or the quickstart document.
- Confirm that you (or your alarm company) have added a keypad to your panel for the AlarmDecoder.
- Confirm the correct keypad address is configured on the device by typing ! and going through the prompts.
- Can you send key presses to the panel?
- Type * (asterisk) You should see Sending.done and the panel should respond with the current status.
- There may be up to five periods between 'Sending' and 'done'. If there are five the keypress has timed out and you should confirm your wiring.
