- The AlarmDecoder GUI is program designed to create a realistic keypad interface to your alarm using the AlarmDecoder device. The program will run on Linux, OSX, Windows and other operating systems that support .Net and Gtk.
- These will be autocratically added to your system if needed during the install process
- .Net or Mono
- Gtk#
- ftdi drivers
Installer
- When you run the program for the first time you will need to set the configuration to communicate with your AD2* device. You can do that from within the program in the "System Menu" or by directly editing the text config files mysettings.conf or ad2usbgui.exe.config . The application must be restarted in order for config file changes to take effect.
