Revision as of 18:25, 21 December 2013 by 204.10.16.29 (Talk)
The AlarmDecoder GUI is program designed to create a realistic keypad interface to your alarm using the AlarmDecoder device. The program will run on Linux, OSX, Windows and other operating systems that support .Net and Gtk.
  • These will be autocratically added to your system if needed during the install process
    • .Net or Mono
    • Gtk#
    • ftdi drivers
Installer
Download the Windows installer now md5:acbf7ce94661f6e2907ab4a44111de0c
Download the Linux installer now md5:53b093f9ee0addaef85c30e909e6a914
Download the OSX installer now
When you run the program for the first time you will need to set the configuration to communicate with your AD2* device. You can do that from within the program in the "System Menu" or by directly editing the text config files mysettings.conf or alarmdecodergui.exe.config . The application must be restarted in order for config file changes to take effect.
