Revision as of 23:18, 31 December 2013 by 204.10.16.28 (Talk)
The AlarmDecoder keypad program create a realistic advanced keypad on any computer running Windows, OSX or Linux. With the open source plugin API and provided plugins it is simple to configure email alerts on alarm events as well as preform other automation tasks. The program will run on Linux, OSX, Windows and other operating systems that support C# and Gtk
For Windows the installer will add these automatically. For OSX and Linux these may need to be installed manually
Installer
Click here to download the Windows installer now
Click here to download the Linux installer now
  • md5 7bac1436fdd2ba4ba2b4dcd6a08baedb
Download the OSX installer now
When you run the program for the first time you will need to set the configuration to communicate with your AD2* device. You can do that from within the program in the "System Menu" or by directly editing the text config files mysettings.conf or alarmdecodergui.exe.config . The application must be restarted in order for config file changes to take effect.
  • Open Source Plugin API
    • C# examples included
  • Network connectible
  • mystuff
    • Email events
  • program downloader
  • zone tracker
  • HTML5 web browser tab
  • Webcam viewer tab
