The AlarmDecoder keypad program create a realistic advanced keypad on any computer running Windows, OSX or Linux. With the open source plugin API and provided plugins it is simple to configure free email alerts on alarm events as well as preform other automation tasks. The program will run on Linux, OSX, Windows and other operating systems that support C# and Gtk
- For Windows the installer will add these automatically. For OSX and Linux these may need to be installed manually
- .Net or Mono
- Windows http://www.microsoft.com/en-us/download/details.aspx?id=17718
- Linux/OSX/Other http://www.mono-project.com/Main_Page
- Gtk#
- Windows: http://download.xamarin.com/GTKforWindows/Windows/gtk-sharp-2.12.22.msi
- Linux: The easiest way is to install Monodevelop
- For the AD2USB version of the AlarmDecoder a usb driver is needed
- http://www.ftdichip.com/Drivers/VCP.htm
- On most Linux distributions the FTDI driver will already be installed
Installer
- Click here to download the Windows installer now
- md5 28778d71524e3d5b5dcee00633fd8fe2
- Includes ftdi drivers and Gtk#
- Some systems may require .Net http://www.nutech.com/images/fbfiles/files/dotnetfx40.exe
- Click here to download the Linux installer now
- md5 7bac1436fdd2ba4ba2b4dcd6a08baedb
- Download the OSX installer now
- When you run the program for the first time you will need to set the configuration to communicate with your AD2* device. You can do that from within the program in the "System Menu" or by directly editing the text config files mysettings.conf or alarmdecodergui.exe.config . The application must be restarted in order for config file changes to take effect.
- Open Source Plugin API
- C# examples included
- Network connectible
- mystuff
- Email events
- program downloader
- zone tracker
- HTML5 web browser tab
- Webcam viewer tab
- mystuff
