- For Windows the installer will add these automatically. For OSX and Linux these may need to be installed manually
- .Net or Mono
- Windows http://www.microsoft.com/en-us/download/details.aspx?id=17718
- Linux/OSX/Other http://www.mono-project.com/Main_Page
- Gtk#
- Windows: http://download.xamarin.com/GTKforWindows/Windows/gtk-sharp-2.12.22.msi
- Linux: The easiest way is to install Monodevelop
- For the AD2USB version of the AlarmDecoder a usb driver is needed
- http://www.ftdichip.com/Drivers/VCP.htm
- On most Linux distributions the FTDI driver will already be installed
Installer
- Click here to download the Windows installer now
- md5 28778d71524e3d5b5dcee00633fd8fe2
- Includes ftdi drivers and Gtk#
- Some systems may require .Net http://www.nutech.com/images/fbfiles/files/dotnetfx40.exe
- Click here to download the Linux installer now
- md5 7bac1436fdd2ba4ba2b4dcd6a08baedb
- Download the OSX installer now
- When you run the program for the first time you will need to set the configuration to communicate with your AD2* device. You can do that from within the program in the "System Menu" or by directly editing the text config files mysettings.conf or alarmdecodergui.exe.config . The application must be restarted in order for config file changes to take effect.
- Open Source Plugin API
- C# examples included
- Network connectible
- mystuff
- Email events
- program downloader
- zone tracker
- HTML5 web browser tab
- Webcam viewer tab
- mystuff
