Revision as of 15:09, 2 January 2014 by 204.10.16.29 (Talk)
The Windows installer will add these requirements automatically. For OSX and Linux these may need to be installed manually.
Installer
Windows - Download the Windows installer
Linux - Download the Linux installer
  • MD5: 7bac1436fdd2ba4ba2b4dcd6a08baedb
OSX - Download the OSX installer
When you run the program for the first time you will need to set the configuration to communicate with your AlarmDecoder device. You can do that from within the program in the "System Menu" or by directly editing the text config files: mysettings.conf or alarmdecodergui.exe.config. The application must be restarted in order for config file changes to take effect.
  • Open Source Plugin API
    • C# examples included
  • Network connectible
  • mystuff
  • Program Downloader
  • Zone Tracker
  • HTML5 web browser tab
  • Webcam viewer tab
