Revision as of 15:04, 13 March 2014 by 204.10.16.29 (Talk)
  • Open Source Plugin API
    • C# examples included
  • Network connectible
  • mystuff
  • Program Downloader
  • Zone Tracker
  • HTML5 web browser tab
  • Webcam viewer tab
Operating System Version MD5
Windows 2.0.10 60b55837d78464bf1fd96758bd241b6d
Linux 2.0.10 c6fbe53293b98fb6018b6d0039301eec
Mac OSX 2.0.10 a2a0db9072c70e9b9ce30c6bf457a4f0
Raw files no install 2.0.9 c0cd0a834fb793099d596bddf9c56b2c
The Windows installer will add these requirements automatically. For OSX and Linux these may need to be installed manually.
