- Open Source Plugin API
- C# examples included
- Network connectible
- Extensions can be loaded or unloaded using the about screen and install plugin menu.
- mystuff
- Example extension, emails events
- Program Downloader
- Zone Tracker
- HTML5 web browser tab
- Webcam viewer tab
- mystuff
Operating System | Version | MD5 |
Windows | 2.0.10 | 522be75b81da0cf1805f1a42038b13c8 |
Linux | 2.0.10 | 6856d107b731de7915cf1bc3c3c4779a |
Mac OSX | 2.0.10 | 9062eb9195e6e6d380edbf836ec62d2a |
Raw files no install | 2.0.9 | c0cd0a834fb793099d596bddf9c56b2c |
- The Windows installer will add these requirements automatically. For OSX and Linux these may need to be installed manually.
- .NET or Mono
- Windows: Download .NET
- Linux/OSX: Download Mono
- Gtk#
- Windows: Download Gtk#
- Linux/OSX: The easiest way is to install Monodevelop
- Drivers - AD2USB only
- Windows: Download FTDI drivers
- Linux/OSX: On most distributions the FTDI driver will already be installed.
