- Open Source Plugin API
- C# examples included
- Network connectible
- Extensions can be loaded or unloaded using the about screen and install plugin menu.
- mystuff
- Example extension, emails events
- Program Downloader
- Zone Tracker
- HTML5 web browser tab
- Webcam viewer tab
- mystuff
Operating System | Version | MD5 |
Windows | 2.0.10 | 052e0415e55e9ea71a506cf109931a11 |
Linux | 2.0.10 | e676236858f1cb11cbe122015b38450b |
Mac OSX | 2.0.10 | 1f95bdffecd6e148c0f98913d5a49bc6 |
Raw files no install | 2.0.10 | 0014c98e3e1409cb49a5e10451b1a702 |
- The Windows installer will add these requirements automatically. For OSX and Linux these may need to be installed manually.
- .NET or Mono
- Windows: Download .NET
- Linux/OSX: Download Mono
- Gtk#
- Windows: Download Gtk#
- Linux/OSX: The easiest way is to install Monodevelop
- Drivers - AD2USB only
- Windows/OSX: Download FTDI drivers
- Linux: On most distributions the FTDI driver will already be installed.
