Revision as of 13:55, 17 March 2014 by 204.10.16.29 (Talk)
  • Open Source Plugin API
    • C# examples included
  • Network connectible
Extensions can be loaded or unloaded using the about screen and install plugin menu.
  • mystuff
  • Program Downloader
  • Zone Tracker
  • HTML5 web browser tab
  • Webcam viewer tab
Operating System Version MD5
Windows 2.0.10 052e0415e55e9ea71a506cf109931a11
Linux 2.0.10 e676236858f1cb11cbe122015b38450b
Mac OSX 2.0.10 1f95bdffecd6e148c0f98913d5a49bc6
Raw files no install 2.0.10 0014c98e3e1409cb49a5e10451b1a702
The Windows installer will add these requirements automatically. For OSX and Linux these may need to be installed manually.
  • .NET or Mono
  • Gtk#
    • Windows: Download Gtk#
    • Linux/OSX: The easiest way is to install Monodevelop
  • Drivers - AD2USB only
    • Windows/OSX 10.8 Mountain Lion: Download FTDI drivers
    • Linux/OSX 10.9 Mavericks: On most distributions the FTDI driver will already be installed.
