Firmware
Revision as of 17:55, 27 July 2015 by 71.237.248.220 (Talk)
The current stable firmware is V2.2a.8. It is not possible to brick the AlarmDecoder but it can get into some states that make firmware updates difficult so be patient when updating the firmware in your AlarmDecoder.
2.2 (AD2USB)
2.2 (AD2SERIAL)
2.2 (AD2PI)
2.0 (AD2USB)
Board Revision Firmware Version
Stable
2.2+ 2.2a.8
2.2+ 2.2a.6
2.0 2.1f.10
Beta
2.2+ 2.2a.9a1
Legacy
2.2+ 2.2a.3
2.2+ 2.2a.2
2.0 2.1f.0e
2.0 2.1f.0d
2.0 1.0f.26
  4. Flash the firmware
    • AlarmDecoder Keypad
    • Console firmware uploader
    • ad2-firmwareupload
