Board Revision | Firmware Version | Revision History |
Stable | ||
2.2+ | 2.2a.8.2 | link |
2.2+ | 2.2a.6 | link |
2.0 | 2.1f.10 | - |
Beta | ||
2.2+ | 2.2a.8.3b | link |
Legacy | ||
2.2+ | 2.2a.3 | - |
2.2+ | 2.2a.2 | - |
2.0 | 2.1f.0e | - |
2.0 | 2.1f.0d | - |
2.0 | 1.0f.26 | - |
- Flashing new firmware will not retain device configuration settings
- Flash the firmware
