- Open Source Plugin API
- C# examples included
- Network connectible
- Extensions can be loaded or unloaded using the about screen and install plugin menu.
- mystuff
- Example extension, emails events
- Program Downloader
- Zone Tracker
- HTML5 web browser tab
- Webcam viewer tab
- mystuff
Operating System | Version | MD5 |
Windows | 2.0.10 | 052e0415e55e9ea71a506cf109931a11 |
Linux | 2.0.10 | e676236858f1cb11cbe122015b38450b |
Mac OSX | 2.0.10 | d1ae7f6a3ab49d93cedf399fbd3b98c7 |
Raw files no install | 2.0.10 | 0014c98e3e1409cb49a5e10451b1a702 |
Update DSC support | 2.0.10 | d38eb8114abf8e32219902a7eff5d50d |
- The Windows and MacOS installers will add most or all of these requirements automatically. For Linux these may need to be installed manually.
- .NET or Mono
- Windows: Download .NET if not already installed ( most likely already installed )
- Linux: Download Mono or install the full Monodevelop package for your distribution
- OSX: Already included in Keypad App for OSX
- Gtk# Manual download Gtk#
- Windows: Already included with installer.
- Linux: The easiest way is to install Monodevelop
- OSX: Mono and Gtk# are already included in the App. Install of Mono or Gtk# is optional and not necessary except for plugin/module development.
- USB to Serial Drivers only needed with AD2USB Manual download FTDI drivers
- Windows Already included with installer.
- Linux/OSX 10.9 Mavericks: On most distributions the FTDI driver will already be installed.
- OSX 10.8 Mountain Lion: Manual download and install FTDI drivers
