Firmware
Revision as of 10:39, 11 September 2017 by 10.10.0.31 (Talk)
2.2 (AD2USB)
2.2 (AD2SERIAL)
2.2 (AD2PI)
2.0 (AD2USB)
Board Revision Firmware Version Revision History
Stable
2.2+ 2.2a.8.6 link
2.2+ 2.2a.6 link
2.0 2.1f.10 -
Beta
2.2+ 2.2a.8.7-297 link
2.2+ 2.2a.8.7a link
2.2+ 2.2a.8.5s link
2.2+ 2.2a.8.3c link
2.2+ 2.2a.8.3b link
Legacy
2.2+ 2.2a.8.2 link
2.2+ 2.2a.3 -
2.2+ 2.2a.2 -
2.0 2.1f.0e -
2.0 2.1f.0d -
2.0 1.0f.26 -
  4. Flash the firmware
    • AlarmDecoder Keypad
    • Console firmware uploader
    • ad2-firmwareupload
