Firmware
Revision as of 15:57, 10 September 2018 by 10.10.0.12 (Talk)
2.2 (AD2USB)
2.2 (AD2SERIAL)
2.2 (AD2PI)
2.0 (AD2USB)
Board Revision Firmware Version Revision History Panel Support
Stable
2.2+ 2.2a.8.8 link DSC, Ademco Vista
Beta
2.2+ 2.2a.8.9-302 link DSC, Ademco Vista
2.2+ 2.2a.8.7-297 link DSC, Ademco Vista
2.2+ 2.2a.8.7a link DSC, Ademco Vista
2.2+ 2.2a.8.5s link DSC, Ademco Vista
2.2+ 2.2a.8.3c link VPLEX BETA
2.2+ 2.2a.8.3b link DSC, Ademco Vista
Legacy
2.2+ 2.2a.8.6 link *DSC(limited), Ademco Vista
2.2+ 2.2a.6 link Ademco Vista
2.0 2.1f.10 - Ademco Vista
2.2+ 2.2a.8.2 link Ademco Vista
2.2+ 2.2a.3 - Ademco Vista
2.2+ 2.2a.2 - Ademco Vista
2.0 2.1f.0e - Ademco Vista
2.0 2.1f.0d - Ademco Vista
2.0 1.0f.26 - Ademco Vista
  2. Download one of the available programs or use the built in firmware uploader in the AlarmDecoder WebApp
  4. Flash the firmware
    • AlarmDecoder WebApp
      • Settings -> Advanced -> Firmware Upload
    • AlarmDecoder Keypad
    • Console firmware uploader
    • ad2-firmwareupload
