Board Revision | Firmware Version | Revision History | Panel Support |
Stable | |||
2.2+ | 2.2a.8.8 | link | DSC, Ademco Vista |
Beta | |||
2.2+ | 2.2a.8.9-303 | link | DSC, Ademco Vista |
2.2+ | 2.2a.8.7-297 | link | DSC, Ademco Vista |
2.2+ | 2.2a.8.7a | link | DSC, Ademco Vista |
2.2+ | 2.2a.8.5s | link | DSC, Ademco Vista |
2.2+ | 2.2a.8.3c | link | VPLEX BETA |
2.2+ | 2.2a.8.3b | link | DSC, Ademco Vista |
Legacy | |||
2.2+ | 2.2a.8.6 | link | *DSC(limited), Ademco Vista |
2.2+ | 2.2a.6 | link | Ademco Vista |
2.0 | 2.1f.10 | - | Ademco Vista |
2.2+ | 2.2a.8.2 | link | Ademco Vista |
2.2+ | 2.2a.3 | - | Ademco Vista |
2.2+ | 2.2a.2 | - | Ademco Vista |
2.0 | 2.1f.0e | - | Ademco Vista |
2.0 | 2.1f.0d | - | Ademco Vista |
2.0 | 1.0f.26 | - | Ademco Vista |
- Flashing new firmware will not retain device configuration settings
- Download one of the available programs or use the built in firmware uploader in the AlarmDecoder WebApp
- Flash the firmware
- AlarmDecoder WebApp
- Settings -> Advanced -> Firmware Upload
